November 22, 2026, 05:27:47 PM
Topic: Rear hatch install  (Read 4481 times)
newprincipal
  • Date Registered: Sep 2013
Ok...I know this thread already exists, but I have been searching the forum for hours.
I want to install a locking hatch in the space in the back of the tank well of my Trident that is clearly intended for that purpose.  Mainly I just want it for accessory access.  Has anyone done this? Seems straight forward.  Cut, smooth, lexel, hatch, screw, seal....thoughts?
CraigVM62
I have installed a couple of hatches and as long as the surface is flat,  it is pretty much as easy as you described.   I also mainly wanted them to access areas normally well out of reach.  I installed the screw in hatch with cat bag so I could also use it to store small items also.
newprincipal
What do you think is the best way to cut the hole?  I have a dremel.  Would a 4" hole saw be easier?
Dan_E
  • Formerly known as Indyflyer
  • Date Registered: Dec 2010
I've installed several hatches and the Dremel worked great each time.
newprincipal
Awesome....universal cutting bit?
A Dremel will definitely do it.  I picked up a Dremel circle cutter a while ago and it works pretty well on plywood and would probably breeze through plastic.  If you go with the circle cutter make sure you tighten and recheck the adjustment knob as you cut.  I have had it loosen up on me before.
If you have some dividers with sharp pointy tips you can trace the circle a few dozen passes and make a nice groove. The dremel will want to take the path of least resistance and follow your trace.
newprincipal
dividers with sharp pointy tips?
Like these here.
newprincipal
Like these here.
d
I used to call that particular device a compass
islandson671
  • Heroes On The Water NWest
  • Date Registered: Jun 2010
Mine turned out so nice and tight I never even bothered to goop it.
newprincipal
Awesome. Thanks so much.
