November 11, 2026, 06:35:13 AM
Topic: Outdoor Kayak Storage  (Read 3412 times)
Martin
  • AOTY: DAngler
  • Date Registered: Apr 2013
Fellow Alaskans
Quick question for you:  I just moved here and right now have no room for the Hobies inside the garage. How do Hobies take freezing temperatures outside?  I have a large covered patio(20x16) that I can put them under, so they wont be in direct harsh weather...but are they at risk of any damage if they endure a winter outside?
Any storage advice is appreciated! Thanks in advance, and I'm loving the area so far!
Martin
« Last Edit: November 17, 2014, 08:43:35 PM by DAngler »
2012 - Hobie Outback
I'm sure it's not optimal but I was in a similar situation. I stored it covered and on its side one whole winter and it was no issue. I'm pretty sure they are as resilient like the garbage bins.
Now if you are in Fairbanks or places where it can dip to 40 below, then all bets are off. I've shattered hockey pucks hitting the goalpost as we played basically nine, 5 minute periods it was so cold. I've seen "flat" tires as well...not "no air" but literally flat like square on one side from sitting, cooling, then rubber basically freezing. Haha.
If you are in Southcentral AK you should be fine.
Martin
  • AOTY: DAngler
Thanks kardinal_84... I'll do just that and hope for the best.
Dirk1730
How's life up in the great white north?
A little crazy weather wise!!! A balmy 43 deg this morning in Anchorage!!!!!  Not sure if that is good or bad.  But other than that life is good!!!!!
What do you think DAngler of your stay?
crackergraham
  • Date Registered: Oct 2014
Curios if anyone has feedback on what impact of cold weather is on transducers.  Particularly the Lowrance ready mount that are integral to the hobies?
6th Place 2015 AOTY
5th Place 2016 AOTY
Martin
  • AOTY: DAngler
So far the weather feels like Washington weather :)    The Air Force weather guys are predicting no heavy winter storms until February...which I'm perfectly fine with!
Kenai_guy
Put it on something that won't deform the hull or put it upside down , then cover it with a tarp.  Make sure something is between it and the ground so it doesn't freeze to the ground.  Tarp it to keep snow and ice out of it.
All of that will make it easier to reactive it's use in the early spring for the homer derby or some fun at WG
9th place 2014 ORC
Mak2014
  • Natural born fish killer
Do you have anything hanging on the garage wall?  I had similar issue with limited space, so I visited Home Depot for cheap u brackets/pipe insulation/locking straps...total $23 and made this contraption:
I have 4 kayaks hanging on these in my garage and they work great. 10 buck and you're done in about 10 minutes.
anyone able to help Graham with his question?
I would think they'd be just fine. You would assume they're built to deal with those temps. Picture a power boat with the transducer permanently installed, that is stored outside.
