November 12, 2026, 01:18:45 AM
Topic: "Barbie Rod" question (sorta)  (Read 4760 times)
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
Technically it's not quite a Barbie rod, but it's close...  I have a little 4 1/2' Shakespeare "Sturdy Stick" that dates back a couple of decades when my son was little.  I just put a $10 Wally World special on it and took it out to play with as a flounder rig.  Then I managed to throw it into the water, of course, since I never tied it to the boat.   ::)  But, since I got lucky and was able to snag the line with my anchor, I hauled it back in and got it back.  Now the spool is full of 15-lb mono (what I had on hand) instead of 8, which leads in a very roundabout way to my question...
If you have heavy(ish) line on one of these little sticks, are you likely to bust the rod if you hook into a decent sized fish?  The rod says "Medium", it looks like it was rated for 8-12 lbs.  Truth be told, that little thing was so much fun I might just get a better spincast reel on it and use it as a main rig.   8)
Jim
just watch where you set your drag tension at.
I put 20lb pink braid on my Barbie Rod.  No problem with the rod breaking.  Believe it or not, those little pink zebco spinning reels have one heck of a lot of drag.  I'm guessing it was up around 10lbs of drag.
-Mark-
Don't be too enthusiastic when setting the hook, and the rod may survive.  I've used medium-weight ice fishing rods about 20 inches long to catch a lot of big pike and lake trout, including a fair number of lake trout which were over 36 inches long.  But last weekend I was ice fishing with a friend who was using a somewhat lighter ice fishing rod, and he hooked a medium-sized pike, set the hook, and busted the rod right above its handle.
Mark Collett
  • Make It Happen
  Hells Fire
  I ran 30 lbs Power pro on my Iron Man pole at ORC last year. It handled fish (though nothing huge) . pulling in a big wad of kelp or two , and hanging up in some UFO.(underwater fuckin' obstacle) more than once. Maybe I should have been using lighter jigs. 3 and 4 oz mostly. And that little pole could throw out quite a good ways when you load it up.
  I think I'll take it out March 14th when lings open in Westport.
Life is short---live it tall.
RoxnDox
  • Native Propel
Thanks for all the info.  Makes me happy to keep using it 😎
Jim
You can catch big fish with little rods.  Here’s the kind of ice fishing rod I use to fish for lake trout and pike, with a level wind trolling reel loaded with 30 pound braid.
These rods can handle big fish.  Here I am with a 37 inch lake trout.
Here I am with a 30 inch lake trout.
Here are a couple of friends catching a 34 inch lake trout:
« Last Edit: February 11, 2015, 07:38:09 PM by pmmpete »
With the right line they can handle big fish with ease.  This guy weighed nearly 15 lbs and was big enough for second place at the 2013 ORC.
RoxnDox
  • Native Propel
Bored at work and googled for "Barbie rod", among other links was this video of a guy pulling in a 100 lb blue shark on one...
Jim
