November 11, 2026, 09:33:38 PM
Topic: Ratchet Straps?  (Read 5016 times)
AKStumpy
  • Date Registered: May 2015
So this is probably a typical noob question (and probably a beaten horse), but are ratchet straps an absolute no-no when strapping kayaks to roof racks/crossbar? I did use them to return home from the kayak shop after purchasing them (not knowing any better), but they did bring an ease of mind knowing the kayaks were not going anywhere at 65mph, especially in the case of strapping down two kayaks. As I started doing research into general kayaking info, I read that rachet straps can cause your kayaks to warp, indent, or even crush/collapse in.
Is there a safe way to use them? Because I am a big fan. I do have tons of buckle straps but don't have the same confidence in them. Is there a way buckle straps can damage the kayaks? Is there a trick to using them?
Hand tighten tensions straps NO RATCHETS and use a bow and stern strap you will be fine the bow and stern lines keep it from going forward or back and the two top lines keep it from being a kite. You can see the bow lines while going down the road
I use ratchets. I also have a warped kayak. I can tell because the hatch doesn't close right. Had that warped by the drive well...that'd suck. It's amazing how little tension it takes to hold it down. DAMHIK.
So hand tightening is plenty. Especially with good bow and stern lines...which I don't use. But I do use extra straps and I also hold the rack down with an insurance strap to the car.
I use ratchet staps. Just dont crank down on them.
CraigVM62
I have been using cam buckle straps since the release is so simple.   I don't imagine needing to tighten the straps any harder than I can pull.   Once the cam is released and locking the strap in place,  I tie a quick half hitch with the tag end for a little extra insurance that it won't loosen.
I do love ratcheting straps for the bikes since you need to compress the suspension to keep them in place.
yaktastic
  • shut up and let me fish.
I have used both.as stated b4 don't over tighten. As long as the slack is out and snug,unless you roll your car its not going anywhere.
4th place 2017 TBKD Rockfish.
  • Visits from AZ
  • Date Registered: Mar 2014
I won't leave home without bow and stern ropes! I've had one accident too many (which was one). Otherwise agree with the above.
2010 OK Scupper Pro
2015 Wilderness Thresher 140
sherminator
You won't go wrong by following generally accepted wisdom as found on this site, but there are plenty of examples of practices that go against the generally accepted wisdom and work well. I use ratchet straps; I carry my yak right-side up; I don't use bow & stern ropes. I have followed these practices for 4 years and many miles now with no problems. However, I support my kayak along the longitudinal axis, do not over tighten the straps (and have flexible supports), and I use secondary straps to keep the kayak attached to my rack in case of primary strap failure.
Use good sense and you will be fine. You are your own captain, which is the best part of being a kayak fisherman...
15x tournament loser
2011 Hobie Oasis (yellow)
2014 Hobie Revo  (red)
I use both depending on where I'm attaching and to what I am attaching to. Mostly I just use the buckle straps around the hull but have come to appreciate rope ratchets for the bow and stern lines over everything else. I also use them for storing them suspended from the ceiling in the shop.
<Proverbs>
