November 23, 2026, 01:38:21 AM
Topic: Rectangular hatch on an older hobie  (Read 3282 times)
kwik
  • Date Registered: Dec 2013
Hey all,
Just wanting to share the recent install of the rectangular hatch install on my older model outback.  Not sure of the exact year but definitely an older model.  In purchasing the hatch it says that it fits 2013 and newer, I think.  I bought it any ways hoping that I can make it work and with some heat from a heat gun and a little "custom" work I was able to make it work.  If Anyone has an older model and is thinking of this mod you will have get the location just right before cutting....there is no wiggle room!
kwik
The first pic shows the outline of the cut.  Note the drainage channels that I had to fill with left over plastic from the cut out section.  I was able to fill the channels by heating the plastic with a heat gun and welding pieces in until flat.
Part of the "custom" work is using 1" #10 ss screw instead of the 3/4 inch that is recommended.
The last pic shows the completed project. A shock bungee cord is ran from the sail post to the seat scupper post to secure the gear on the inside.
I also recorded the install with the gopro but may need some time to edit it together.
kwik
One more
  • Chris
Nice install! You can check the last two digits of the serial to figure out the year of your boat.
8th Place 2014 AOTD
1st Place 2013 AOTD
Sponsorship and Support:
Waxer's Surf Shop
Hobie Fishing Team
Lancer Jigs
Pro-Cure Scents
kwik
Do you know where they put the serial number?
  • Date Registered: Oct 2009
kwik
Thanks to both of you!  Found the sn it's an 03
