November 11, 2026, 07:22:14 AM
Topic: Drill holes (little ones) with confidence! Repairs are easy.  (Read 5380 times)
Low_Sky
Repairing screw holes in your polyethylene kayak is actually pretty easy.  Well within the skill set and budget of most of us.  So don't lose sleep over getting that accessory mount or pad eye in EXACTLY the right place the first time.
To repair screw holes in your hull, you'll need a mini torch, some filler material and a sharp knife/fine tip scissors/side cutters.
I use a Bernzomatic ST500T, which I picked up at the big box hardware store for $20.
For filler material, I used some 1/8" HDPE filler rod that I had for a bigger plastic welding project.  If you want something that matches your boat, you can try the "Hobie" colored filler rods (you'll end up with a bunch of colors you don't need if you buy this), or you can probably use just about any other source of HDPE that you can fashion into something long enough to hold onto, and skinny enough to fit into the hole you are trying to fill.
You'll want to set up the torch in "hot air blower" mode, with the flame arrestor installed, no soldering tip.  This shoots a jet of extremely hot air.  The ST500T doesn't go to 11, so I settle for 4 (max output).
Heat the hole and the end of the filler rod at the same time, but don't let them touch.  You're looking for the plastic immediately surrounding the hole to take on sort of a shiny appearance, and for the end of the filler rod to start drooping and melting a bit.  When everything is nice and soft, kill the torch, and stick the filler rod into the hole.  I give the rod a few spins to make sure it mixes with the hull plastic.  Hold everything in place for a few seconds while the plastic cools and sets up.  Once it's solid, cut off the filler rod and use a razor blade or sharp knife to shave off any excess plastic flush with the hull.
I used this technique to fill in some screw holes in my brand new Hobie hull, since I wanted to remove one of the mesh pockets, and didn't want to use line-snagging screws to fill the holes.
No action shots, but here is the result:
« Last Edit: March 31, 2016, 12:49:47 PM by Low_Sky »
2016 Hobie Revolution 16
2014 Perception Triumph 13
  • Date Registered: Aug 2015
Thanks for the write up, that's great to know.
saltykayAK
  • Date Registered: Jun 2015
Not the preferred method, but I have assisted in an emergency fix before that involved a cigarette lighter, plastic Folgers coffee can, and a cracked hull on a kayak. Definitely not perfect, but it got us through the last two days off paddling on the boundary waters canoe area.
Nice job and you can see in a closer examination that when twisted it definitely molded with the boat. I like it
Low_Sky
Plenty of screw holes to be filled in a Hobie.  The screws that hold down the useless molded rod holder caps are another great candidate for removal.
Looks like a solid fix!
Note, keep all the curly bits from drilling holes in your kayak.  They work awesone for repairing the same kayak.
I just renoved a RAM ball from my Revo that wasn't seeing any use.
These were 3/16" holes.
Before, after and replaced the texture in the area to really hide them.
Low_Sky
Awesome repair, Insayn. How did you texture your holes?
Heated the area up with a heat gun, and then pressed a 24 grit air tool disk, and then heated up again and pressed with 60 grit.
Low_Sky
Just in time!  I'm about to move a ball mount from the left to the right side...  Thanks.
DTS
Insayn,  great repair!  Those pictures show the repair better than in person. When I seen your kayak in person, I couldn't even tell that there had ever been any holes in it.  8)
PROGRESS IS JUST BEING THERE!
What repair  ??? That's two different boats ::).... Obviously  ;)
Thanks for the write-up. I like this method better than some of the others I've seen for hole repair - I just mean the actual physical method of putting the patch material in the hole and twisting.
