November 21, 2026, 08:34:20 PM
[Today at 08:11:50 PM]
Topic: Garmin Striker Sonar Transducer ?  (Read 3603 times)
9unner
  • Date Registered: Apr 2016
Does anyone know if the new Garmin Striker Sonar transducer will fit a Hobie PA14 2015 were the Lorance ready transducer would go?
Thanks,
Dark Tuna
  • "Dark Tuna?"
  • Date Registered: Aug 2014
Post a question at Austin Kayak.  The were helpful when I asked about the Raymarine transducer.
Skidplate
If it's their GT20 transducer, it does not fit perfectly in other Lowrance ready boats. (specifically the Revo 13) But you can make it fit by altering the cover; I went so far as to heating up the boat plastic inside the cavity a bit to remold it 1/4" for more clearance.
Fairly easy mod.
Idaho Brit
  • Date Registered: Jun 2016
I have a garmin echomap 43dv. The transducer would not mount on the trans cover on my 2016 outback due to the shape of the trans. Too fat in front compared to the lowrance. But it fits into the recess without modifying the cover. I just installed under the cover and let gravity take over. I sits on the cover level and due to its shape it can't go anywhere. I installed it without the bracket supplied by garmin. I was thinking of cutting a piece of rubber sheet to cushion it from the cover. Or you could work out some other way to suspend it in there. For me right now it works great as I only fish on local lakes. Im not sure if its a similar transponder to yours but it is doable if it is.
