November 11, 2026, 07:20:17 PM
Topic: How heavy of an anchor should I use?  (Read 10385 times)
Outdoorguy1
  • Date Registered: Jun 2016
How heavy of an anchor should I use when fishing in the   Lyle wa area of the  Columbia river and what type if I decide to anchor up and fish in the fall? I probley mostly be trolling thoe. Alittle help pl. I will be fishing from a kayak..
« Last Edit: June 23, 2016, 09:13:40 PM by Outdoorguy1 »
Pyramid and 5-10 lbs.
Outdoorguy1
Thanks for the info I was kinda leaning towards that anchor.
Outdoorguy1
Ten lbs seems kinda light to me thoe but I don't know that's why I was wondering I was thinking 25lb or is that over Kill?
Wayy over kill.
25 lbs is better suited for power boats, unless you are anchoring your kayak in rapids.   :o
5-10 is sufficient.  In fact, in many cases two kayaks can hang from a 10 lb anchor.
woo
  • Date Registered: Apr 2014
RU sure you want to use an anchor in a river?  I would worry about a submerged log catching/tangling the anchor line and dragging my kayak down. I know you can do a quick release  system, but then you may loose your anchor - just a thought. Any other thoughts on this or a safer method?
cdat
If 10 lbs won't hold you in the river, you shouldn't be anchored in that spot, the current is moving too fast.  Take a look at some of the posts regarding anchor set-ups, a quick release connection is a must for anchoring in moving water.
John
MurseStrong
  • Date Registered: Dec 2013
A little help? You should change your name to "Silverplatterguy1." Do your homework dude, it's all right there for you with a little effort.
-The Old Man and the Sea
Outdoorguy1
Well with the research I have done I didn't find a  definite awnser. I  thought I  ask someone who had some  experience  Anchoring on the river I'm gonna go to. Instead of some where that doesn't apply .
Outdoorguy1
Thanks for those  safety tips most of all . It's all about being safe and having fun in everything you do..😄
Pinstriper
  • Date Registered: May 2015
If you are in water moving so fast that a 25# anchor is needed to hold a kayak, I doubt you would ever be able to paddle upstream to get off it and retrieve it. That is not anchorable water in a kayak, in my non-expert view.
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
You would absolutely be correct with that thought.
yaktastic
  • shut up and let me fish.
5 lbs is just fine.it all depends on where you fish there though.just add some chain.im using a 10 lb dumbbell and it's way over kill.just what I got. Just be careful not to be the guy who anchors up right at the mouth.hover fishing is not anchoring.
4th place 2017 TBKD Rockfish.
Eugene
  • 2015 WS Thresher 140
  • Date Registered: Aug 2015
Outdoorguy1
Love it thanks lots of good info out there thanks😀
