November 22, 2026, 06:23:59 PM
[Today at 05:32:50 PM]
Topic: Boondox Rudder upgrade.  (Read 4351 times)
Got the new rudder for TLW's boat Friday and installed it yesterday, no OTW test till this morning....BIG MISTAKE. Got the boats rigged and my son and I carried them down got him launched then I launch right behind him and put full left rudder and pulled the cables right out of the handle jam plate ?!?!?! DOH!!!! Beached the boat got a screwdriver out and got it back together in a hurry to catch my kid and the tide. Mistake #2 not even close to centered ?!?!?! DOH AGAIN!!! It's good enough to get the crab traps set, then beached it again. THIS TIME I'm doing the freaking job right and get it centered and just enough tension it don't free turn. Love the rudder but I found out not to make fast moves with the handle when going full rudder as it pushes ALOT of water and you end up reefing on the handles and cables. The boat turns faster sharper and now will turn in reverse. Fairly simple to do but be sure to use lock tight on the bolt.
smokeyangler
  • Date Registered: Feb 2014
Sounds like you had quite the test and tune on Game day.  I bet you'll be happy with it now that you have all the bugs worked out of it.
2014 Hobie PA 14
2015 Hobie Outback
hdpwipmonkey
  • Date Registered: Nov 2014
Wow!  That looks beefy!  If you get going fast and give it full rudder does it throw you out of the boat?   😀
Sent from my SHIELD Tablet K1 using Tapatalk
Ray
www.facebook.com/HOWNOC
2016 Junk Jig Challenge
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
No but it makes you think about your weight distribution and balance a little  more!
Jim (same boat, also with Boonedox rudder...)
