November 18, 2026, 03:39:11 PM
[Today at 11:13:08 AM]
Topic: Lost of lot of fishing time  (Read 5400 times)
Pinstriper
  • Date Registered: May 2015
Cleaning up tangles.
Yesterday I was trolling - a Brad's cut plug, an actual cut plug herring with a helmet, and a thumper spinner.
The spinner was fine, except constantly pulling it up to clean the weeds off - so much for trolling close to the bottom, but at least the tackle was working.
With the others, I kept getting everything twisted up on itself and also with the dropper (18" dropper off a slider, 6 oz and 8 oz). Of course when this happens you don't really know it, and its a knotfest and the twists are permanently set in the leader so I just had to chop it up and retie.
I had bead chain swivels and barrel swivels at both ends, no flasher. My theory is that once something picks up a weed, the swivels/chains don't spin any more but the bait continues spinning and you get a wonderful twist up.
Also, my technique was to hold onto the cannonball until I was in motion, then release the weight, but maybe that's backwards ? Should I be dropping the weight and holding the bait until the rig starts to trail, then throw the bait in and then let out line to get to depth ?
I've had this happen while trolling from a PB also, apparently I'm not doing anything particularly wrong, or the guys I was with are also idiots (more than normal for PBers, I mean).
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
snopro
Try this, shorten your dropper length to 8" and use weed guards above your swivels.  You can also use a two section leader with heavier line in front and lighter line on the hooks.
On deployment, I let my rig  run beside about a foot down for a few seconds to check for herring spin and then slowly lower it to the bottom.
You should have said something Pinstriper, I would have helped get you deployed without the tangled. Next trip out we will set up early and get you rigged to match mine and work on deployment technique.
Pinstriper
I DID tell you, and the only fishing advice you gave out all day was "don't do anything to prepare".
Corey, back me up, here.
Let's eat Grandma !
Helium Head
I know I heard it... After he caught his salmon!
Hobie Revolution 13 olive
Hobie Revolution 13 yellow
Come on now I showed y'all my rig while we were getting preped. Thinking about a repeat performance Tuesday or Wednesday if someone want to go.
SSAL
  • Date Registered: Sep 2015
I've always wondered about the tangling issue. What do you guys think about trangle flashers vs dodgers? Seems like the thumping of a dodger can be used as feedback the gears' working correctly.
