November 18, 2026, 07:15:39 AM
Topic: mysterioso question  (Read 4075 times)
yessnoo
  • Date Registered: Apr 2008
ok i have this mysterioso set now...kinda wish i woulda gotten an xl top instead of just L but when i lose some weight from kayaking it should fit better :)
anyways was just curious if you can wash and dry it as if it were regular t shirt?
by the way i used it basically by itself accept the shorts and hat i had on...it works very well to keep you warm if you are dry or wet...but when you are actually in the water it does almost nothing for you lol...shortly after you get out the fleece liner dries (like in a matter of minutes) and you warm up again...the outer layer seems to take a very long time to dry out....also after several hours of the outer layer being wet i noticed when the wind picked up you would start to get a chill...but it isn't really meant to be a stand alone suit i don't think lol....
im thinking i would be too hot in it unless it was pretty cold out...i had to carry the kayak up the hill to my house on my new wheeleez cart and man i sweating so bad lol...i took the top and the socks off too
Alkasazi
  • Alkasazi
typically you'll want to wash & line dry. dryer is usually too hot the material. should be a tag somewhere on the clothing where you can confirm this.
