November 23, 2026, 02:33:38 PM
[Today at 11:47:34 AM]
Topic: Torqueedo 403 motor kit  (Read 3849 times)
It's time for me to upgrade to an electric motor if I want to continue fishing for any extended period of time or distance. I have looked at all the options and have decided the Torqueedo 403 ultralight motor would work best for my needs. The 403 is $350 cheaper than the Hobie Evolve, and it has a better mounting option. I want to be able to keep and use the sailing rudder for steering, and I don't want to have a motor kicking around loose in the yak when not deployed. The Evolve has two mounting options, either using the drive well, or replacing the rudder. The 403 mounts on a pivot either in back of the rudder, or over the side. It swings up out of the way when not in use, and allows for the Mirage drive to stay mounted in the drive well. I was hoping to get a NWKA discount at one of the Torqueedo dealers, but it doesn't look like that is going to happen. If anyone has had any experience with this drive, or knows of a good deal on one, please let me know!
Dan_E
  • Formerly known as Indyflyer
  • Date Registered: Dec 2010
For a good deal you might look at some of the DIY motors on youtube.  They are more affordable than either of the commercial models.  There are other DIY videos for Hobie kayak motors that have some interesting ideas for mounting through the drive well.
I am going to stick with the Torqueedo. I have a Revo 11, and weight is important. Also, I like the variable speed forward and reverse.
smokeyangler
  • Date Registered: Feb 2014
I don't know much about them, but you might take a look at the Bixby swim jet also.  I've looked at the Torqueedo and it seems like it's built well.  The weight savings and being able to still use your mirage drive and rudder are a plus.  If you end up getting one be sure to write up a review.
2014 Hobie PA 14
2015 Hobie Outback
upnorthtex
  • Outback/ texas power paddle
The 403 is an excellent choice when we get older and need insurance to get home. I also have an evolve that I got a little cheaper because I wanted an extra battery. Not impressed with either of the mounting choices. Several of us had trouble with water intrusion when motor mounted on rudder. Motor is trash when that happens. I've used my 403 in many different kayak types , all worked well. The diy or redneck systems can work well, I've used a few before I spent the big bucks,  but none were really satisfactory for me only because of the big heavy battery, which can really change stability. Stick with the 403 you'll be good with it. Art
Thanks Art, I have already figured out how I want to mount it, and take advantage of the ability to swing it out of the way, while still being able to reach the drive in case of it getting fouled with stuff. The reliability is my main concern. Using it to be able to get back on the salt, and fish for salmon in the rivers is the main reason I am going this route. You have always been an inspiration for me, and I respect your opinions.
Dave
