November 23, 2026, 07:06:37 AM
Topic: Low current ff/chart plotter recommendations?  (Read 4615 times)
Kyle M
I'm replacing my lowrance HDS5 for more battery time. I'm fine with a 4" screen. I don't really trust posted specs, but maybe they are correct? Anyway, actual experience would be good to hear about, and I'd like to get a full day on an SLA. The Lowrance online manuals say 1.1amp draw for the Hook4 through 9, and that can't be right.
thanks!
Sent from my SM-G930V using Tapatalk
« Last Edit: September 22, 2017, 07:11:41 AM by Kyle M »
rogerdodger
  • Fish Retriever
  • roger
  • Date Registered: Dec 2012
I think the larger screen size units (>"5") will absolutely draw more current than 1.1amp.
I am very pleased with the "4" series Lowrance, mine is an Elite4chip, my guess is the newer versions have similar current draw and I can run all day on a small $10 SLA battery that weights 4#:
https://www.atbatt.com/amstron-12v-6ah-ap-1250f2-sealed-lead-acid-battery.asp
« Last Edit: September 22, 2017, 04:15:18 PM by rogerdodger »
JasonM
  • Date Registered: Jun 2017
I have a Lowrance Hook 4. The highest draw that I have seen from it in a few rounds of testing was 508mA briefly during startup after being reset to factory defaults, with typical draw around 320 to 330mA with the brightness set to max (where I always keep it). I bought it at West Marine for $200 because it was in a package with a cover and a maps card. It was cheaper than the Hook 4 alone because the package deal was getting discontinued. I got the package with the Lake Insights Pro card but they still have the package with the Nautic Pro card for that price.
Lowrance Hook-4 Fishfinder/Chartplotter with CHIRP, DownScan Transducer, Nautic Insight™ Pro Cartography
https://www.westmarine.com/buy/lowrance--hook-4-fishfinder-chartplotter-with-chirp-downscan-transducer-nautic-insight-pro-cartography--17933805
I can't say that I care that much about either of those maps cards, but the cover is nice and I saved money compared to just buying the fish finder itself. I like it so far, but I haven't really used it to its fullest potential yet. It can do a lot more than I know how to do with it.  :D
Cosmo
  • DADventurerNW
Kyle,
I have a Hook 5 and an Elite 5. Both draw about 1amp per hour, but that is on full brightness 10.  I run split screens all the time, and like the brightness turned up.  I run a 9 amp hour battery, Cabelas makes a pretty compact one that's only $30.  I can run all day on this battery, with all the bells and whistles on.
However, if you turn down the brightness to 5 or 6, it cuts the power draw by almost half.
Aside from the power draw, why do you want to downsize the screen?  When I moved up from a 4 to a 5, it was a huge difference, especially when running split screens.
Cosmo
2 Hobie Mirage Outbacks 2014
AKFishOn
  • Date Registered: Dec 2015
Not sure about different fishfinders, but I picked up a 12v, 12AH Duracell AGM for $48 at Batteries Plus, should be able to power any fishfinder for a good while. Got sick of buying smaller SLA batteries only to have them die after less than a year of moderate use.  I've had an AGM in my truck for 10 years so far with no problems. https://www.batteriesplus.com/productdetails/sla12=12f2
Kyle M
Thanks for the advice. I don't really want to downsize the screen, but simply want to increase battery life. I'll look into the ff and battery suggestions.
I have an Elite-4 CHIRP and a HOOK-5.  I can run either all day on a 8 amp SLA with either set to the brightest screen setting and using the DSI screen.  I went with 8amps to fit an existing battery box.
The Elite-4 will draw the battery down from 12.6 volts (full charge) to 12.3 volts after 8 hours.
The HOOK-5 will draw it down to 12.1 volts after 8 hours.
Using an 18,000 mAh blue brick, either the Elite or the HOOK will drop the voltage from 12.1 (full charge) to ~11.2 in 6 hours.  There's pretty much no difference in battery life between the two finders.  I don't use that battery for extended trips.
I don't know how old your battery may be, but they do get old and start to discharge quickly.
Hope that helps.
« Last Edit: September 22, 2017, 04:25:28 PM by Tinker »
Kyle M
I think my battery may be getting old, but decided to order the Hook4. I'll be getting a new SLA as well.
