November 23, 2026, 05:44:46 AM
Topic: Kayak repair  (Read 6668 times)
Trident 13
  • Date Registered: Jul 2016
Saw this on the "PaddleNews" weekly email, thought it might give someone a place to start.
https://paddling.com/learn/kayak-repair/
« Last Edit: November 01, 2017, 07:57:39 AM by Trident 13 »
Thanks for the link.  I need to fill the 1-inch hole I drilled in a Tarpon before I give it to my Grandkid and didn't know where to start.  Timely.
« Last Edit: November 01, 2017, 12:36:11 PM by Tinker »
Hydrospider
Thanks for sharing this interesting read.
Here is a NWKA resource with some photos of PE repairs.
Not nearly as all encompassing as this article, but the photos are of real plastic welds.
http://www.northwestkayakanglers.com/index.php?topic=19254.0
What I would do there is just take a piece of cheap 1/4" cutting board, cut and shape it to fit inside that entire rectangle area. Then scuff up the kayak area, as well as the back of the cutting board with 80 grit paper, and thoroughly GOOP it down.  If you can reach under from the hatch there, you could secure it with screws/nuts in 4 to 6 places as well.   GOOP is your friend, use it liberally!
« Last Edit: November 04, 2017, 01:36:22 PM by INSAYN »
Thought about doing this the other day then thought about my fabricating skills... they're a nit lacking these days.  But I think it makes the most sense - now that you've suggested it - and I'll just have to buy a whole bunch of cutting boards and keep trying until I get it correctly shaped.  Thank you.
Hole saw 1/4 to 1/2 inch bigger then the hole (depending on space  around the existing hole) drill two pieces out of cutting board material goop one on top and one on the bottom and a nut and bolt that’s the same size as the hole saws drill bit to sandwich it all together.
DWB123
  • Date Registered: Aug 2013
Are you planning to mount a fish finder?  you could use the hole and one of the Hobie wire-plugs (I think that's what they were called).
Or K.I.S.S. and goop a rubber stopper in there. https://www.homedepot.com/p/Everbilt-1-1-4-in-x-1-in-Black-Rubber-Stopper-808278/204273370
This kayak goes to my Granddaughter.  While both of your suggestions would surely fill the hole, I'm hoping for something closer to a restoration.  But I won't rule out a rubber stopper or the thru-hull plug - they definitely fit my skills more closely.   ;D
Thank you both.
skidlybo
  • Date Registered: Sep 2014
If you have a sheet metal or fab shop nearby you might be able to score a thin gauge aluminum or stainless punch out.  They look like coins.  Maybe 1 1/4" punch out and glue it down with a bead of marine grade urethane sealant.   Heck you could glue down a 50 cent piece.
« Last Edit: November 04, 2017, 09:41:29 PM by skidlybo »
Or just cut out a piece of thin cutting board from the Dollar Tree to fit the rectangle area.  Scuff both the boat and the piece.  GOOP that sucker down.  Done!  Nobody would ever know there was a hole there unless you told them.
Hydrospider
 It seems that folks here are suggesting alternatives to a traditional plastic weld.
Is there a reason why?
This job is a straight forward patch and smooth. Its on a flat area and away from scuppers,
there is access to both sides of the hole, and Tinker has experience in hull repairs.
 Im not suggesting that any of these are bad ideas, but why avoid the standard plastic kayak repair techniques?
skidlybo
I'm just guessing but it sounded like Tinker was looking for a quick repair idea with minimal time, tools, and expertise required.  That being said, without a doubt a plastic weld would be the gold standard repair method.
I'm going to give the plastic weld a try on the rear keel area of my OK Trident.  I don't want to find out how thin it is when I'm on the water.  One feature I liked on the Jackson Cuda I used to own was the replaceable rear keel strip.
I'd been looking at it as needing a 1" disc to fit/fill the hole - not hard to make - which led me to wondering how to support the disc and keep it aligned (flat) while welding it in place.  I've had reasonable success patching smaller holes and I've smoothed deeply gouged keels - none anywhere near as damaged as the keel you fixed - but I've never worked on a hole this size and I can use all the suggestions I can get.  Thank you for bringing welding back into the discussion.
I got the impression Tinker wanted a fix that would look clean and not "repaired".  A small 1/4" hole or smaller could easily be welded to look natural. A 1" hole, not so easily.
