November 23, 2026, 06:21:10 AM
Topic: Gear track drill bit  (Read 4767 times)
Chromer
  • Date Registered: Dec 2016
Just bought a pair of YakAttack gt90 gear tracks and fullbacks for the rear tankwell of my revolution 13.  I haven’t been able to find the size drill bit used for their installation.  This is my time first drilling in my new boat so I want to get everything right.
Thanks,
Joe
PetitPoisson
  • Date Registered: Aug 2017
I made my own tracks but did follow the YakAttack dimensions fairly closely (you can read my DIY gear track project in the "drilling and cutting" section of the forum).  I seem to recall the GT90 used an 8/32 screw.  I'm going by memory so... "If that's correct", you can use either an 11/64 drill bit or a 3/16 drill bit.  The 3/16 will give you slightly more "wiggle" room to work with and is the one I would use.  You will find the thickness of our kayaks is not consistent from one hole to the next (hole spacing on your track should be 1-3/4).  Be sure to add some marine sealant between your boat and the track at each hole you drill.
You'll also get a bunch of plastic spirals when you drill the screw holes.  You might want to collect these.  You may need to do a small repair in the future and it will be nice to have a little plastic available in the right colour if you do.
Hobie Oasis (Le Phoque)
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
Take the tracks in to your local hardware store and pick the drill bit :)  I have done that many times, make sure I get the right sizes...
Chromer
Thanks for the replies, I finally finished my install.  The first track went in fine but the second one had a problem with the backing plate.  Yak Attack sent me a new one within a few days which was awesome and the second one went in quickly.  The biggest lesson I learned was drilling into a kayak isn’t that big of a deal.
Please disregard my messy garage.
« Last Edit: December 20, 2017, 09:47:16 PM by Chromer »
PetitPoisson
Looks good.  So what size drill bit did you end up using?
Chromer
I used an 11/64 drill bit.
You sure the second backing plate didn’t work because of a defect or was it that your garage was upside down? ???
Low_Sky
Everyone's a first timer the first time.  Nothing to get excited about until you start thinking about hole saws and Dremel tools.  ;)
2016 Hobie Revolution 16
2014 Perception Triumph 13
That's a great looking install!  Nice work!
Chromer
Thanks rawkfish!  One of the reasons I got gear tracks was because I saw them in some of your videos.  Even though I have drilled 28 holes in total, the versatility of the gear tracks made outfitting much easier and more universal.
Low_Sky
Oh yeah, I forgot to say congrats on the nice, clean looking install  :)
The nice thing about small holes is that if you ever change your mind about what/where accessories, the holes can be easily filled with some basic plastic welding skills.
