October 28, 2026, 08:02:22 PM
Topic: 12 volt power supplies  (Read 34717 times)
b0w_bender
  • Pat Moore - in Issaquah Wa.
  • Date Registered: Nov 2020
I have one of the inexpensive Garmin Striker 4 fish finder units. It has a very small screen. With that unit and the 18V battery I've gone 5 or 6 hours on a single charge. Can't say how long it would actually have worked because I run out of juice peddling before the battery does. I can't speak for the larger fish finders but I found it to be more than adequate. However good info folks should certainly test for themselves with their own setup.
"Experience" is what you get when you didn't get what you wanted.
If you teach a kid to Shoot or fish you will be rewarded with a lifetime of smiles.
workhard
  • Date Registered: Sep 2015
I have a 9AH with a 7" Lowerance Elite2, I keep it at the brightness where I can barely see it to make it last an entire trip.
SD2OR
  • Date Registered: Jul 2020
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
1st Place Team Event BCS 2023
2nd Place AOTY 2022
1st Place Tiny Fish Slam 2022
YakHunter
  • Retired!
  • Date Registered: Jun 2020
I never considered using a power tool battery to power kayak gear. Can someone please provide a picture of the adapter used to connect such a battery to a fish finder? What is that part called, and can it power a small trolling motor? Thanks in advance!
I just saw your request.  I purchased a battery dock power connector off Amazon which I mounted into a small waterproof case.  Used a power step down converter to drop voltage to 12v.  It has waterproof female SAE pigtail connector plus a waterproof dual USB plug.  This setup allows me to utilize my Dewalt batteries for power and is readily portable.
Hobie PA14
Hobie Adventure Island
Hobie Tandem Island
Jackson CudaHD
BlueSky 360 Angler
b0w_bender
Ya that is a nice setup!
SD2OR
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
