November 13, 2026, 05:44:50 AM
Topic: f/s 2016 Hobie i11s  (Read 6252 times)
Dan_E
  • Formerly known as Indyflyer
  • Date Registered: Dec 2010
I'm selling my Hobie i11s inflatable, bought in April 2016.  It has the turbo fins and sailing rudder, the training fins and rudder are included in the sale.  Includes mirage drive carry bag, Hobie kayak carry bag, Hobie hand pump, Hobie scupper cart and Hobie paddle.  The seat has the cup holder and a pack attached to it that holds two water bottles, lunch and a bunch of other stuff as you want.  I'll include the Coleman cordless electric pump I use for the center tube.
It has a small cut on the hull as seen in the picture, courtesy of the Salmon river estuary.  It did not cut the fabric, just the rubberized coating.  Repaired IAW with Hobie instructions.  No leaks ever, everything work as intended, kept the drive and cables lubed IAW Hobie recommendations.
I had a trolling motor on it so it is registered as you can see.  Due for renewal at the end of the year, you maybe can de-register it if you want but the numbers ain't coming off the hull!
Asking $1,400, located in McMinnville, could meet at Hagg if someone wants to try-it before they buy-it.
I'm downsizing the herd, and not using the Hobie as much as I should, it needs a good home where it will see the water more often.
Daniel
