November 11, 2026, 03:45:34 PM
Topic: crab pot line question  (Read 5226 times)
showa
  • Date Registered: May 2016
I have 100 feet of leaded crab pot line, but I want to add another 100 feet of none leaded line. Can I do that? if I can, should I tie the none leaded line to the crab pot or on the buoy end?
Thanks in advance.
DWB123
  • Date Registered: Aug 2013
you can do whatever you want, but that's a lot of line. shrimping, perhaps?
you'll want to attach the non-weighted line to the crab pot side, so that the leaded line is attached to your float, and sinks beneath the surface. floating line on the surface poses a danger to other boaters, and i believe is illegal to use unless weighted down here in WA.
showa
I like to do crabbing in Kayak point, but there are deep drop off and you get crab if you drop to 160 feet. I will buy the leaded line, thank you for your reply.
« Last Edit: July 07, 2020, 01:52:37 PM by showa »
Not.  The weather closed the door, COVID-19 just locked it.
hdpwipmonkey
  • Date Registered: Nov 2014
 :dontknow:   :laughing4:
I think Tinker finally lost it...
Ray
www.facebook.com/HOWNOC
2016 Junk Jig Challenge
showa
I think you are correct hdpwipmonkey ;D
