October 30, 2026, 03:44:03 AM
Topic: Removable crab and shrimp pot weights -- Do they exist?  (Read 9089 times)
BiggyZee
  • Date Registered: Feb 2021
After reading and watching videos it seems like hauling 30lbs+ pots from the deep is an intense workout.
Is there some kind of clip that I could attach to the trap?
There would be weights attached to the clips, and the clip would have its own line. With a nice tug I could dislodge the clips and pull it in with a large fishing reel. After reeling in the weighted clips manually pull up a much lighter pot.
If it doesn't exist I had an idea with a custom hitch-pin, similar to a descending device.
SD2OR
  • Date Registered: Jul 2020
Maybe use light duty zip ties, that would break with a nice tug of the rod? Or some light monofilament?
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
1st Place Team Event BCS 2023
2nd Place AOTY 2022
1st Place Tiny Fish Slam 2022
BiggyZee
I believe your interpretation of the intensity level is overblown.  What you describe is unnecessarily complex.  I put 5 pounds of rebar in my Danielson traps and call it good.  The only time I've really struggled was in 70' with a trap of 20+ crab and that was with a bum shoulder.
Dave
Fair enough. I'll probably try it the normal way first and see how I fare.
This application was mainly for spot shrimping in Puget sound where people recommend 400ft of line and 20lbs+ of weights.
diverdoyle
  • Date Registered: Jun 2011
Good luck with spot shrimp in a yak somethings are better left to a larger boat
Dawn Patrol
  • Date Registered: Nov 2017
I’ve seen positive sounding reports around kayak shrimping on here, but  when a buddy and I tried it (early in our kayak fishing careers) we retroactively named the day “Black Saturday” and he actually bought a PB the next week as a direct result.
Full pots with 20+ weights 200’+ deep and with current is no joke. Shrimp escape the pots if it’s slow or inconsistent pressure on the way up, heartbreaking to watch live after all the effort.
I like your thinking about the breakaway weight, that might help. I actually have a lighter shrimp pot I pulled up with a downrigger on a PB that I am holding onto in case I want to try the kayak method ever again. Regardless of do-ability, I found it pretty inefficient on the kayak so these days stick to PB’s with an electric puller.
BiggyZee
It seems like shrimp pots on kayak is no joke :laugh:. People seem to struggle manually pulling even on a boat.
Had another idea modifying the mesh on those casting crab traps, as well as putting some "fingers" at the end like a venus fly trap. WDFW emailed me saying it was OK if the mesh size meets the gear requirements. I'd probably let it soak for 10-15 minutes then retrieve. Don't really have a big freezer so I would just keep enough shrimp for a catch n cook, and maybe another meal day. That also means no need for a big heavy pot to yak around.  ;D
I'll attach a drawing of the breakaway weight idea.
bogueYaker
  • Date Registered: Aug 2019
Give it a shot, experimenting can be fun. Maybe try it out in freshwater before the season starts so you don't ruin a day of crabbing ;).
Interpreting your blueprint literally, I wonder if having the weight mounted on the side would cause the trap to tend to lay on it's side.
BiggyZee
Will do. Still waiting on the second half of my kayak  :laugh:
It was supposed to be 4 weights each one on a corner. Or maybe just 2 laying flat side down. Hoping my Penn 8000 reel can take the weight.
diverdoyle
side note   is a  great place  for  weights is  thrift  stores / good wills   get the  richard  simmons  coated  1-5# weights  for really cheap  there
You are making him sad bro.  :sad10:
