November 26, 2026, 05:51:06 PM
[Today at 05:16:12 PM]
Topic: Coho vs. Chinook  (Read 4717 times)
SD2OR
  • Date Registered: Jul 2020
So, I have been out numerous times in the last couple months, and have done pretty well on the coho. Have caught em on triangle and 360, cutplugs, swimbaits, trolling flies and spoons....
Ususally 25' or less on the depth counter.
My question: is there anything I can be doing to increase my chances of hooking a chinook?
One day I was out, and watched Clayman get one, but he wasn't doing anything different than what I just described. Last time I was out, I'm certain a fish I lost at the boat was a nook.
At times, I have tried trolling deeper, 50-75', but got few take downs and only 1 coho, if memory serves. I've yet to get a chinook out of my kayak, and would really like to change that. I've seen posts of others scoring them...does one just need to be lucky to find the chinook needle in the coho stack?
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
1st Place Team Event BCS 2023
2nd Place AOTY 2022
1st Place Tiny Fish Slam 2022
bogueYaker
  • Date Registered: Aug 2019
In my experience, the best way to catch a chinook is by fishing for coho. Chances really go up once chinook retention closes.
lol.
SD2OR
LOL! Sounds about right!
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
Clayman
  • Date Registered: Feb 2017
Try trolling really close to shore and near the bottom, say 30-50 FOW. Use cut-plug or a whole herring, either behind a triangle flasher or no flasher at all (no flasher at all is called a "straight bait" presentation). This time of year, many of the Chinook are hugging the shoreline while traveling south towards their respective spawning streams. They'll be less interested in lures, but a well-presented herring can be tough for them to pass up. You'll also avoid most of the coho by fishing tight to shore and close to the bottom. Expect fewer bites, but the bites you do get will most likely be Chinook.
aMayesing Bros.
SD2OR
Awesome, thanks for that Clayman!
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
T Coastal
  • Date Registered: Apr 2019
Generally you'll wanna troll deep and slow. .5 to 1.5 MPH, also fish deep. I've always just gone as deep as I can, 60-90 feet usually? Unless you wanna use a downrigger the next best thing is a Deep 6 diver (one of the big ones) and let out about 190 feet of line. You'll be in the right zone.
2020 Hobie Outback
2018 Ocean Kayak Prowler 13
SD2OR
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
workhard
  • Date Registered: Sep 2015
+1. Good advice for ocean Chinook late in the season.
I tried this for about 90 minutes yesterday morning of out of Pacific City. I hooked a lot of fish! But they were all rockfish and lingcod.
When using this strategy do you just take a ton of bait with you and plan on rebaiting often, or was I too close to structure? (I was in 35-50 FOW the entire time, mostly sandy bottom.)
Clayman
If you're doing it around structure, you'll inevitably burn through a lot of bait due to rockfish and lings. I prefer to do it away from structure, but sometimes the salmon are up on the reef, so that's where you gotta go.
I fished PC for a couple hours Friday morning, and the water was frigid (48 degrees) and crystal clear. Not conducive to holding salmon.
aMayesing Bros.
OK, thanks, makes sense. Yeah, I noticed the 48F on the fish finder and thought that was a bit on the cold side. It was ~51F at ~80FOW.
