October 02, 2026, 02:48:51 PM
[Today at 10:54:03 AM]
Topic: Mirage Drive 180 Roller Bearings  (Read 7323 times)
SD2OR
  • Date Registered: Jul 2020
Some intolerable speaking, that lube did not help, caused me to disassemble my drive. I discovered several  roller bearings had broken apart. I've been looking online for a bit now, can't find em for sale anywhere.
 I fabricated a few out of aluminum, was all I had that was the right size. It's been a good functional temporary fix, but I'm sure the metal will start to cause wear to the parts around it before long.
Does anyone know where I could purchase said bearings, or a length of plastic rod, that I could cut into bearings?
Thanks in advance!
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
1st Place Team Event BCS 2023
2nd Place AOTY 2022
1st Place Tiny Fish Slam 2022
Nick W
  • Date Registered: Mar 2017
When I had issues with mine our dealer up here said it couldn’t hurt to submit a claim even though my warranty had expired, and Hobie gave me 40 percent off a new lower spine assembly, so that may be an option for you if this is on your 2021 Outback in your signature? A lot easier to change the whole assembly than messing with the individual bearings too.
I probably have some good spare roller bearings in my old spine assembly if you do need them. The way mine wore, I would think aluminum and grit would probably chew it up pretty quick in there. I had the thought to try to figure out how to change that whole little drum out that the bearings ride on with a piece of round aluminum but I’ll never get to it
kredden
  • Date Registered: Feb 2018
I should have some lying around at the shop (Outdoor Emporium in Seattle).  When I do repairs and replace sprockets and such I usually keep the old bearings just in case I need them.  I pretty sure I also have a bunch of brand new (the long skinny ones, not the short fat ones).
If you still need, give me a call the the store tomorrow, 206-624-6550 and ask for Kevin.
SD2OR
Thanks for the info!
Yeah, my 2021. The wear on mine is very similar to yours, not quite as bad.
It was a pain to reassemble, for sure.
I'll contact Hobie n see what they say.
The roller bearings don't seem to be any sort of special material, will continue to search  for a plastic rod of correct diameter, to cut my own.
Will post if I find something viable.
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
SD2OR
Kevin-
          You must have posted about the same time I did. Will for sure give you a call tomorrow.  Thanks!
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
SFHarry
Enter this into Amazon and pick one for your project. 1/4 inch Delrin rod. I have replaced my broken bearings with this. I personally hate the 180 drive and would rather have a GT drive. I treat mine gently and have still replaced the spine several times under warranty. It's making noise now...
Hobie Outbacks 2019, 2012
DOA Humboldt Kayak Group 2012-2023
GS8, GS9, GSX, GS11, GS12, GS13
Rockfish Wars 2014, 2015, 2016
AKA: Hobie-Wan Kenobi
SD2OR
I'm inclined to agree with you.
The kick up fins are a constant pain.
I've performed virtually zero maintenance on my '07 drive, (I'm its second owner too) and it's still  going strong. Admittedly,  it hasn't seen much use since I got my 2021.
I'll check out the item you recommended,  thank you!
« Last Edit: May 28, 2023, 12:36:44 PM by SD2OR »
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
SD2OR
Kudos to Kevin and Outdoor Emporium for going above and beyond to help me!
Check em out!
but why risk it?
13th place BCS 2026
2nd place AOTY 2025
2nd Place AOTY 2024
3rd Place AOTY 2023
3rd Place ORC 2023
2nd Place AOTY 2022
kredden
I didn't see an e-mail from you with your address yet.  My e-mail is [email protected].
Kevin
If you Google the part number you can usually find the bearings available somewhere. It gets tedious if you need to order 5 different things and have to do it from 5 different places, but you can usually find what you're looking for.
You can lift the part numbers for the roller bearings from this video:
Related: I just tore down, inspected, and re-lubed my MD-180 (not kickup) drive for the first time, and really wish I'd started doing it sooner. I had quite a bit of sand/grit damage. Not enough to replace the spine but more than I wanted (similar to photo above). Lesson learned: Now all 4 of my drives are getting a once-a-year teardown, clean, and rebuild.
