November 18, 2026, 09:03:56 AM
Topic: Eagle Cuda 350  (Read 7248 times)
C-legs
Anybody any good with one  ???, I have a question about something I can't figure out.
ok? :dontknow:   fire away
C-legs
While in the split GPS/sonar screen I'm trying to zoom in on the map and its zooming in on the sonar. How do I get it to go back and function for the map?
Well, I didn't get to try it on my ff yet, but I tried it on the emulator (I'm assuming that you want to remain in split screen mode), and the map zoomed and not the sonar. :dontknow:
 If it ain't so on your Cuda 350 then this will be the second difference I've run into between the Lowrance and the Eagle units.
http://www.lowrance.com/upload/Lowrance/Emulators/M56M_demo.exe
http://www.lowrance.com/upload/Lowrance/Emulators/M68C_demo.exe
BTW: Those emulators are a slick way to play with your FF and find the features without having to be in your boat. The tide/current work fine as soon as you zoom out of Tulsa, OK and get to a coast. ;D
Again, similarities between the M56 and the Cuda 350 are greater than the differences. It's worth the effort.
« Last Edit: February 17, 2010, 12:39:32 PM by Fishesfromtupperware »
SwiftDraw
 Hey Fishesfromtupperware
Does the Cuda 350 have other demos such as for the gps - way points, trails etc. etc?
Chuck
Chuck
The only Eagle emulator I found is for the Cuda 240, but that is step or two back as it does not seem to have any charts at all. Again, I have the Lowrance M68 and M56, and the M56 is virtually identical to the Cuda 350. That emulator does do trails, waypoint....etc.  if you set the gps setup to "gps simulator".
http://www.eaglenav.com/upload/Eagle/Emulators/Cuda240sGPS_demo.exe
C-legs
Regarding the original post, whike in the mode I mentioned all I had to do was hit "pages" twice to switch from sonar or map.
Wouldnt you know, I found this out by reading the manual.  :)
