November 12, 2026, 03:11:34 PM
[Today at 01:27:15 PM]
Topic: Couple questions on rigging the FF  (Read 5493 times)
DO NOT forget the Marine GOOP
Yes, very important.  Everyone who has a fishing kayak should have a bottle of this stuff just lying around.
If you happen to forget it though, I believe Nestucca Valley Sporting Goods carries it in your neck o' the woods.
BorderYakker
  • All Fish in photos are larger than they appear.
  • My Facebook page.
  • Date Registered: Jul 2010
While my method might not be too pretty it was very effective for my T-13...
I used the transducer that came with the FF. Turned the yak upside-down and placed it where I wanted it to be. Taped it in place with masking tape. Turned the yak back over and put epoxy around the transducer. Be sure to leave a hole to allow water to drain around it. Works like a champ. It has been in place for two years and I land on the beach and put the yak in the back of my truck with no problems. It looks like a little plug in the hole.
The epoxy is probably an inch or so thick.
Fairly easy and effective.
Always looking for new fishing spots and tactics. I pretty much catch and release everything.
 2. the t13 has a transducer scupper. how far does a transducer hang below the hull?
The proper transducer fits into the hollow molded into the hull.  The transducer does not hang down at all.
http://www.demonick.com/kayak/FF.GPS/transducer.html
3. other than having to drill for the scupper mount. which has the advantage?
No need to drill a hole for the transducer cable.  You can coil up and tie-wrap the excess cable and put the coil in the sonar shield.  Use the sonar shield drains to route the cable.
http://www.demonick.com/kayak/FF.GPS/mount.html
