October 28, 2026, 05:46:06 PM
Topic: Jigs  (Read 5711 times)
AlfonsoVisaya
My buddies and I are always trying to come up with ways to save mulah so as to survive in the dry world away from our yaks.  Check out these jigs:  http://humboldttuna.com/smf/index.php?topic=546.0
That one made it on the site even before your post. It's a popular one that made it on NCKA too.
Yarjammer
  • Captain of the Titanic
  • Date Registered: May 2008
Those are pretty sweet, I may have to try my hand at those this winter.  I saved a bunch of cash gearing up for ORC2010 by making my own pipe jigs out of rebar.  One of the great things about using rebar is you can use a chart like the one below in planning what weight jig you are wanting to make.  They sell one and two foot sections dirt cheap at Home Depoe.
boxofrain
  • Date Registered: May 2006
I made some knife jigs and tossing irons from those very posts.
 They work as well as any $5 jig/lure on the market.
 Thanks eric!
For some time my plan for weighting crab traps has been to tie-wrap 4 18" sections of rebar on the bottom of the 2'x2' folding traps.  Something else on my list for HD.  I'll be back on the water Monday!
that works well for the Danialson's traps.  Give the rebar a good layer of "coat it" rubberized paint (or wrap with old innertube) to keep the rust at bay.  I have found two pieces (20ish inches) are enough for the ocean down here.
I split a 12" piece of 1.5" steel tubing down the center. Laid them down side by side and welded end caps on them.  Melted lead and poured.  Drilled two holes each and zip tied to the bottom of my cage.
Do you weld your grilled cheese sandwiches too? ;D
I bet he cuts them in half with his Plasma cutter ;D
Oh dudes, speaking of Grilled Cheese..There's a joint here in Coos Bay called Forby's(i highly recommend it for burgers, get a double). Well anyway, they got a burger where the buns are replaced with two grilled cheese sandwiches..yes you read that right, two GC sando's!!! It's glorious, i had one a couple days ago...
Back to topic..I got a handful of knives from the thrift store and am gonna make me somne of those jigs, very inspiring that thread was.
boxofrain
Old window counter weights work quite well for keeping yer traps from walking too.
 I have no idea how much they actually weigh, butt they were free!
 :banjo:
Great idea! I'm gonna do it. On my way to CB. Fishing Sunset tomorrow AM.
rrdstarr
  • Date Registered: May 2010
I just use leaded rope to sink my crab trap!  My old shoulder doesn't want to haul up to damn much weight, but maybe I need to add a little bit to keep it from drifting.
-Rick
Pygmy Boats - Borealis XL
Great.  2x20" and "Coat It" it is.
So 120' of leaded rope doesn't weigh anything?
rrdstarr
120 feet does weigh a bit, so I actually cut it to 50' cause I put my traps down at 30' +/-.
-Rick
