November 18, 2026, 09:54:26 AM
Topic: HX-760 S  (Read 3513 times)
demonicks review of the HX 850 series handhelds got me thinking.. Since I'm kind of multi tasking challenged, meaning i cant' fish, paddle and use the hand held at the same time, what if i suggest to the MFR that they make a Blue Tooth enabled radio??
So, i emailed them  ::) This is what i got back;
Thank you for contacting Standard Horizon.
The HX760S is our Bluetooth model which is supplied with a water
resistant headset. If you need a waterproof headset you would have to
contact another company http://www.cellphoneshop.net/xii.html and use
their headset on the HX760S.
Best regards,
Scott Iverson
The HX760S has blue tooth capabilities, but it's not DSC like the HX850.
yeh, i should'a been more specific... well, maybe they'll take the hint and produce an 1100 series or something with all that...
There's not much multi-tasking unless you are actively communicating over the radio.  Basically, it is just clipped to your PFD monitoring Channel 16 or turned off for emergency use only.
