November 13, 2026, 02:23:47 AM
Topic: Accurate Boss B270 magnum, pristine, hotrodded  (Read 5976 times)
kallitype
  • Vashon Island kayaker
  New reel, just rebuilt and jazzed up by Alan Tani, reel guru supreme.   90 second  free spool, Carbontex drag, top of the line bearings with hightech lube.  Will pull 30# of drag!!  Great tuna reel, or trophy halibut or sturgeon reel.  Small but mighty.  Pics follow.  Spooled with 65# Jerry Brown Spectra, 30# mono topshot.  Might as well have the best!!  Twin drag, no torque.  Accurate reels are generally thought to be the best saltwater reel on the market.
Accurate Reels is dedicated to outfitting anglers with the highest quality fishing tackle. Other manufacturers may use descriptions such as double-disc drag or dual disc drag, but no other reel's two-faced drag system can compare with the performance of Accurate’s exclusive, patented TwinDrag system. Accurate’s unique TwinDrag, with its heat resistant titanium friction washers, applies equal pressure to both sides of the spool. This not only reduces heat buildup, but allows for a perfectly balanced load and less wear on reel bearings, spool and washers. That translates into stronger, smoother drags — and more accurate drag settings. TwinDrag reels also offer excellent, unhindered freespooling in every drag-setting range from less than one-pound to total lock-down of up to 100 pounds. No other reel’s drag system can compare in smoothness, performance and durability to Accurate’s patented TwinDrag.
  $300.
kallitype
same as in pic, but with custom red handle knob.  Comes with reel bag.  Custom reel clamp, philips head instead of allen head screws.
That is one sweet little machine!
Schwing!
kallitype
Tackletour actually got 58# of drag out of it, it nearly wrecked their testing machine.  Enough drag to pull you over the side by a big halibut!!!\\
http://www.tackletour.com/reviewaccuratebossmagnumeseries197pg2.html
kallitype
kallitype
the price you're asking is a steal... i really hope it goes quickly for you..
kallitype
Thanks Rich!!!  Me too---I have both the Saltist 40hi speed and this one up fer sale, will keep whatever doesn't sell for my primary trolling reel.  The Saltist is sort of an ugly duckling and big, but strong and fast....
