November 06, 2026, 11:08:31 AM
Topic: Kayak rivets  (Read 9793 times)
Guppy Tamer
  • Date Registered: Jun 2011
Does anyone know a local supplier for the specialized rivets for kayaks? Preferably in the Salem area.
Sent from my DROID2 GLOBAL using Tapatalk
Wish I had an answer for ya.  That's a big thing that frustrated me about Salem - no kayak shops.  I always ended up buying stuff online or waiting until I made a trip up to Portland.
Sent from a dead raccoon I installed Linux on.
Whats a kayak specialized rivet?
I think he means the expanded ones with the 3 prongs while not invented for kayaks  do work well
There are rivets out there that have a little rubber gasket underneath the head of the rivet that people like to use for kayaks.  I think they were originally designed for aircraft.
Wali does have a good point though.  You don't really need to use any particular rivets.  Find aluminum rivets that will fit into a 3/16" hole and get some PVC thread tape - the kind that plumbers use.  Wrap the shaft of the rivet just below the head a few times nice & tight.  This will give you a nice gasket for your rivet so you won't have to worry about leakage.
« Last Edit: July 06, 2011, 10:59:43 AM by rawkfish »
Who has them in the portland area?
Guppy Tamer
What are they called, and what size do you typically use?
Guppy Tamer
And I figured out how to get rid of that annoying signature block from the phone!
We had a bunch out on the table at the ORC due to a generous donation from someone whose name escapes me.  They weren't all used up and I have a bunch left over.  Send me a PM with your address and I'll send a handful your way.
I just use as  long of an normal aluminum rivet i can find and goop it generously. Never had one leak or pull out yet.
Don't get the stainless steel ones. oh crap those are a PITA! unless you got a real fancy rivet gun. I couldn't even get 'em to pop, had to cut them off with the dremel. I quit and went and got aluminum to finish the job.
I was just messin with ya!   ;)
bluewrx02
  • Facebook
DTS donated them.
2011 Hobie Outback
2013 Hobie Revo 13
2014 Hobie Adventure Island
Stumblefish
 I went to Dick's sporting goods and got the paddle holder bunjee and a rear cargo bunjee kit, with the intent of using the supplied bolts and having the 4 sided rivets for other things. Hook1 has some iirc, not sure.I wish i saw them at ORC, a few more extras would be nice  for my small fix kit in my truck. I still have 4 left, they were too small imo to fasten a Scotty holder the way i wanted.
Before I bought 200 of them from DTS at the ORC (thanks again for the great deal!).  About a month prior I picked some up at Next Adventure in PDX.
I only use rivets in areas without enought access to allow stainless steel bolts.  Scotty rod holders always get the SS Bolt treatment as they take A Lot of Abuse!
