November 06, 2026, 07:26:27 AM
Topic: How Do You Carry Your Balls?!@#$  (Read 6714 times)
fishnut
  • Date Registered: Aug 2009
Downrigger balls that is. How do you guys store them on your yak? ???
Inside the milk crate or attached to the DR.
+1
Which begs the question, how big are your balls?
Not to sound like I'm bragging...4 pounds.
snopro
Rolling around by my feet. ;D
4-6lbs. I like to run 4 lbs, but in the sound I need 6 to get my desired results. My 1st ball (that was lost to the sound) was 8lbs and not totally unmanageable, but made things pretty interesting. I won't run heavier than 6lbs on the yak any more.
I stick with 6 pounds, any lighter and I get too much blow back.
rrdstarr
  • Date Registered: May 2010
Just bought the Scotty 1073 Down rigger yesterday and it is to be used with a 2-4 ball.  Bought a three.  Going out this afternoon after salmon!!!
-Rick
Pygmy Boats - Borealis XL
I tried DR'ing with a 3 pound ball and got all kinds of blow back...Let us know how it works for ya.
rrdstarr
What do you mean by Blowback?
-Rick
It means the DR line isn't vertical, it should be pretty close to vertical
Depending on how deep you're trolling, speed, and current your DR line angle w/ a 6# ball should be around 45 degrees. W/ a Scotty Depthmaster DR it's line counter is calibrated for that and depth is very accurate.
I would switch out the wire for spectra.  It makes a world of difference (much smaller diameter thus less drag) and it is much easier to cut in an emergency situation.
