November 06, 2026, 05:36:19 AM
Topic: My Prowler Trident 15  (Read 4405 times)
Yester
  • Date Registered: Dec 2011
Just want to say Hi and that maybe one of these days get the chance to fish with you folks.  But here is my kayak from NCKA.    http://www.norcalkayakanglers.com/index.php/topic,34751.msg371151.html#msg371151
« Last Edit: December 15, 2011, 01:32:32 PM by Yester »
Deluxeharley
  • "Live like Ron"
  • Date Registered: Jun 2011
What kind of speed and coverage do you get on a full charge?
Cool. How much does it weigh fully loaded? What type of water do you usually use it in? Do you still live in Nor Cal? If so where abouts?
Yester
Haven't got her tested on the water yet?  I'll let you know how that goes once it starts raining.
I'm not sure I could weigh everything but my battery weighs in at 48lbs.  I'll try to weigh the motor.  Haven't got the lady in the water but should be able to do more river fishing, but mainly the Delta is where she gets wet.  Still live in NorCal, Sacramento.
Yester
So I'd weigh the battery again for couple times and it came out 49.2lbs.  Added just the trolling motor section only along with the battery and it came up to 66.2lbs.  So just the trolling motor section is at 17lbs.
« Last Edit: December 16, 2011, 01:39:06 PM by Yester »
Get that sucker on the water!
And get some fish blood stains brewing on deck.   ;)
so boat, seat, and propulsion system, to include the other incidentals such as the control pedals etc, should weigh in roughly@125lbs.  Add in weight of operator, ancillary gear and tackle, = ____?  T15's are rated @ 500-550 lbs capacity.......
Yester, not to take away from you and your mods, how much is that motor designed to push ? I was graciously given the mod plans for a cobra triple using a tohatsu 3 h.p. smoker, this seems like it would work a bit better.
Yester
That is a great question because it all comes down to how much weight is on the kayak, wind, water current.  I would think the only way I could show some numbers is a fish finder.  However, I don't have one yet.
« Last Edit: December 19, 2011, 07:05:05 PM by Yester »
