November 23, 2026, 08:50:52 AM
Topic: Fish Pics?? AOTY and others.  (Read 6116 times)
jgrady
  • Date Registered: Mar 2010
Im a bit Confused about Some of the Fish Pics and How they are done.I Don't have a good camera to take pics ,But also don'thave a fish YET. But for the AOTY arn't the Fish sappose to Still be Alive? and Not Gutted? And Do You Have to Use a Fish Trough or can a Tape or Yardstick work?I guess Pole's Comment of this last years Pic Problem is on My Mind too. Fish Mouth Shut .OK I get that But WHAT KIND OF Camera do some of you others guys and gals. use..do you wait till on shore to take the pic? or What?OH ya and I do hope to have a fish Soon.. ???
They don't have to be alive.
I suppose it should be spelled out that any mutilation to the fish that is perceived to extend the length of the fish is not acceptable ... I wouldn't gut it.
You can use anything that shows a clear measurement.  It is best if the measurement is on a flat surface with the measuring device under the fish, and not draped over it on a curve.
The mouth does NOT have to be completely shut.  It can be in a natural, relaxed open position.  But if you can shut it, then do so.
jgrady
Thanks That helps.Im also thinking Waterproof camera would help..
jstonick
I bought an Olympus tough model  from Costco a year or two ago that is waterproof and seems to work well. I have left it sitting in a puddle in my kayak all day and it still has worked perfectly. The only bad thing about my camera is that it takes non-standard cards and has a non-standard micro-USB connector.  I think that there are a lot of good candidates out there and that you just need to keep your eyes peeled for a sale! Also, it may be that a waterproof video camera that could take stills may be a better choice.
Weird.  My Olympus Stylus Tough takes SD cards.  Absolutely great camera though.  I beat the hell out of it and it keeps going.
I have an Olympus Stylus 1030 and has taken a beating, dunked, salted, dropped in the sand etc....
Still takes great pictures.
Mine takes the XD card, and I can't find anything larger than 2g. That's a lot of pictures, and my battery usually dies way before I run out of card capacity. To remedy this, I just ordered a new aftermarket battery that has higher capacity from Amazon for like $8.
jstonick
I have the Olympus Stylus Tough 6000. It uses an xD-Picture Card (not SD). There is an adapter included for using a micro SD card (It is an xD shell that the micro-SD plugs into). Perhaps my camera is a bit older and the newer ones take SD cards.
jstonick
The limit on XD cards is 2gig. I think even if you stick in an 8gig micro SD card into the converter that the camera will only recognize 2gig of memory.
 I have not a problem with battery life since I only take a handful of pictures at a time. I only charge the camera up a couple of times a year - after it goes dead on a fishing trip usually  >:(
+1 on the Olympus Stylus cameras.  I still use the same one I bought back in 2007 and it still works great.  It's closing in on taking its 10,000th picture.
For those who may be overwhelmed at the prospect of having to buy a camera to compete;  YOU DO NOT HAVE TO BUY A BRAND NEW CAMERA TO BE COMPETITIVE.  Just be careful with your gear and keep it in a drybag till you need to use it.
I competed for 2 years using my trusty old family digital camera.  And didn't do too badly those two years.  ;D
Old faithfull finally died from a fatal fall off the kitchen counter.  :-[
If you want to go the cheap route for now do a search on amazon for waterproof digital camera. There are some kodaks you can pick up for 60-70 bucks that will get the job done. They probably don't take the greatest landscapes but they will certainly get a clear photo of a fish at two feet.
That said:  "Life can be tough, this camera is tougher. Rugged metal body and innovative shock-absorbing construction are designed to withstand a 6.6-foot drop, bump, or other mishap."  -Olympusamerica.com
I have an older Pentax Optio WP camera.  So far mine has gone for swims and spent an extended time in a wet pdf with no ill affects.  They also take a standard SD cad which is nice.
flyry
My wife has an Olympus waterproof point and shoot, and we have gone scuba diving to 30ft just goofin around and it did find.  +1 to Olympus
No matter which waterproof camera you buy, try and get the optional silicon rubber skin for it. It's a lot easier to grip the camera when its wet, or when your hands are covered with fish slime! It also helps the camera stay in your vest pocket. I have one for my Pentax Optio W60 and love it!
