November 06, 2026, 05:51:03 PM
Topic: scotty anchor system  (Read 6693 times)
sydwayz04
hey all just ordered my first kayak and will be here tomorrow, a acsend fs 10, wanting a anchor system off the back. plan on using it mostly in streams for fishing and duck hunting, have seen some of the home made anchor systems on here but has anybody used a factory one like the scotty, are there any other ones out there? any help would be great, thanks
Yup, the scotty works well. If you're using in any sort of current it's generally good to remove the locking mechanism and just secure the line to a cleat close at hand. The thinking being if you get into trouble you can release the rope and float way from a snagged anchor. See a couple of pics below, flip forward. Don't use it with a claw anchor in a stream or river, try and find around a 10 lb pyramid. The claw snags too easy and is hard to free.
https://picasaweb.google.com/110768604748454700400/KayakPhotos#5609747466259679490
sydwayz04
yes was gonna make my own pyramid anchor and i hade the same idea on the cleat close bu and good to know the scotty one is removeable, thanks for the help
Kenai_guy
I use my Scotty anchor setup in lakes and slow moving waters and it works great.  Yet to try it in deep or fast water, but still like it.
9th place 2014 ORC
sydwayz04
sounds good i will give it a try, new yak should be here around 5, gotta see where i can mount the bracket to a flat spot at first, thanks tho for the replies
I second all of Noah's comments.
sydwayz04
ok well got the new yak today and there is no way i can mount a anchor off the back due to,  1 the reat storage hangs down way to low to cralw back there and 2 both ends are filled with foam and would be a pain to chizel out if i even could in the back, so instead i ordered the wilderness brand anchore trolly systym and there tension cleate deal, so guess that will halt to work for now,
noah... so are u diving sunday, just realized your pic is the same at ncuh, and realized who you were, good luck this year and be safe in the water
Can you take a picture of what you're talking about? Also, I think you might have me confused with someone else. I don't know what ncuh is :)
sydwayz04
lol yes i am thinking about someone else, just looked were u live in your signature, sorry :-)  but thats weird... "ncuh" is nor cal underwater hunters, it was a diving and spear fishing forum from back when i lived in ca, there is a guy who screen name is noah that has a pic of his kayak under the noyo harbor bridge in fort bragg ca, just thought it was you
and what do u want a picture of the non excessable rear of the yak ?
That picture is actually the bridge at Depoe Bay, OR. Just the rear of the kayak. Could you just put a flush mount scotty on the rear?
PikeYaker
  • Leave nothing on the beach but footprints!!!!!!!!!
  • Date Registered: Sep 2011
I would say either a flush mount or regular block mount on the back would work fantastic...
check this out..
http://www.scottypaddlesports.com/kayak-fishing-equipment-accessories/accessories/anchorlock.html
mount your block or flush mount in the back. Scotty even has rivets you can buy that would superb, put this anchor lock on the back and away you go
Wilderness Systems Tarpon 120 Angler
sydwayz04
the problem with the scotty mounts is i thought u needed to bolt it through the yak and put a washer and nut on the bottom, which there is no way to get to it, but rivets would be great of they were long enough and strong enough, and do u think they would be strong enough with the anchor always dangeling on it, or when anchored in the current  and its pulling on the bracket ?
PikeYaker
Check out Scotty's extra long rivets. They are an expanding rivet so they don't just mushroom slightly they expand out and get a great grip. Much like the bolt drywall anchors.
PikeYaker
Just be sure to silicon the holes good. I have mounted lots of attachments in the rear of my boat using this style of rivet and no issues.
