November 11, 2026, 02:13:52 PM
Topic: penn drag washer dimension to upgrade spinning reels and others....  (Read 3523 times)
alantani
here is a list of the 25 smaller drag ht-100 drag washers that penn makes. the washers are listed by part #, followed by price as listed in pennparts.com as of this date (2/13/05), followed by the inner diameter in millimeters, the outer diameter in millimeters and the thickness in millimeters. what follows after that is a listing of the common reels that use this drag washer.
for the engineers in the group, my methodology is as follows. i bought an "el cheapo" 0-6" (150mm) "performance tool" digital caliper (stock #w80153) from my local auto parts store for $20. i have a plano storage box filled with 26 different penn ht-100 drag washers purchased from pennparts.com. i reached into the box and grabbed one washer at random. i did a single measurement for the inner diameter if round or a minimum and a maximum if the inside hole was hexagonal in shape. i did a single measurement of the outer diameter, not including the "keys" if the drag washer was keyed. "keyed" washers are so noted. i also did a single measurement of the thickness. the actually mm's displayed on the digital screen was listed, although the results should be considered accurate only to the "tenth" of a millimeter, not the "hundreth."
in the future, i will start a list of penn drag washers that fit in other brands of reels. you may measure the stock drag washers in your reel, compare the dimensions (don't forget to account for thickness) and order drag washers accordingly. your local shop should be able to obtain the washers for you and also obtain shimano drag grease if you so desire. this list will be updated periodically, along with an evergrowing list of reels. each update will be numbered and dated. as always, e-mail me for questions at [email protected]. good luck. alan
penn drag washer part # (price) / id x od x thickness in millimeters / reel
#6-25 ($6.00) / hex 22.88 min, 26.07 max x 54.13 x 1.22 / 25 gls, shimano tld 15
#6-49 ($1.00) / 10.55 x 28.67 x 0.95 / 49L super mariner
#6-60 ($0.75) / 10.61 x 20.44 x 0.92 / long beach 60, 140 squidder
#6-113 ($1.15) / 10.50 x 20.45 x 1.13 / senator 113 black
#6-113h ($1.40) / 13.06 x 27.02 x 1.34 / senator 113h red, calcutta 250
#6-114 ($1.15) / 15.16 x 24.25 x 1.23 / senator 114 black
#6-115 ($1.50) / 14.82 x 29.54 x 1.33 / senator 114h red, 115 black
#6-116 ($2.75) / 16.55 x 32.69 x 1.36 / senator 116 black
#6-117 ($2.75)/ 16.58 x 38.64 x 1.18 / senator 117 black, 118 black
#6-155 ($0.65) / 10.65 x 17.92 x 0.93 / 155 beachmaster
#6-309 ($1.10) / 10.76 x 24.59 x 0.93 / 500 jigmaster, 975, calcutta 700
#6-320 ($1.25) / 12.85 x 29.02 x 0.96 / 320 gti-gt2
#6-320LD ($8.50) / hex 19.18 min, 20.71 max x 45.88 x 1.25 / 320 lever drag
#6-525 ($1.50) / 10.55 x keyed 28.67 x 1.26 / graphite 525-535-545-555, 113hn
#6-855 ($1.00) / 11.99 x 21.48 x 1.21 / 855 line counter
#6-875 ($1.00) / 13.06 x 25.01 x 1.23 / 875 line counter
#6-895 ($1.25) / 16.05 x 29.47 x 1.29 / 895 line counter
#6-965 ($0.90) / 8.15 x 24.61 x 0.85 / 955-965, calcutta 400, trn100/200g
#6B-965 ($1.00) / 15.24 x 24.30 x 0.93 / 955-965-975, calcutta 400, trn100/200g
#6-975LD ($1.00) / 15.12 x keyed 38.25 x 1.08 / 975 lever drag
#6-5600 ($2.90) / 14.60 x keyed 41.15 x 1.15 / 4600-5600 live liner
#6-7000 ($1.75) / 5.08 x 21.54 x 1.14 / 7000 powergraph
#56-440 ($1.50) / 8.88 x keyed 30.93 / 0.90 / 440 ss
#56-710 ($0.90) / 7.92 x 14.68 x 1.22 / 710z spinfisher
#56-4200 ($1.25) / 8.44 x keyed 26.29 x 0.95 / 4200 ss
