October 04, 2026, 06:04:44 PM
Topic: FF scupper mount  (Read 2687 times)
NWnoob
So this week I plan on getting my FF/GPS combo, which I hope to have set-up for my first time crabbing.  Anyway, Ive seen some discussion on here about the scupper mounted transducers and the good/bad.  If I remember correctly it seemed like some people tried it and didnt seem too happy so they went back to the hull mounted.  My question is, is there anyone with a scupper mount sitting around?  I would like to try this first before I mount the puck in my hull.  Also, has anyone put a scupper mount on an OK Prowler with the special scupper for the transducer?  How well did it fit?  Thanks everyone
2nd place 2012 Salmon SlayRide
2nd place 2013 Salmon SlayRide
1st place 2014 Salmon SlayRide
jim-dawg
I had a prowler trident 15 with the transducer scupper and mounted my hummingbird transducer through it and it work great.
jim-dawg
P.S. I thought that I needed a washer on the shaft of the 'ducer before the nut went on and it nearly sealed the scupper completely so I took it back off and then it drained just fine.
I put a scupper transducer on my Trident13 and used a breadboard washer I made with a couple of hole saws.  The key is to make the plastic washer, then cut about 30 degrees out of it, and orient the washer's slot with the drainage lead.
jim-dawg
I was going to do something similar 'cause it just looked like it needed a washer (lack of nut surface contacting the 'yak) but ended up buying a new outback and took the hummingbird with me and mounting it thru-hull in the outback.
