November 21, 2026, 08:44:28 PM
[Today at 08:11:50 PM]
Topic: Truck Rack  (Read 12267 times)
Any way to drill the bolt shafts and put a small padlock on it thinking like a jeep spare tire rack was on the back.
Pinstriper
  • Date Registered: May 2015
"Like a Jeep..."
No way. Barbie had a Jeep. Forget it.
Let's eat, Grandma !
Let's eat Grandma !
Punctuation. It saves lives.
"Like a Jeep..."
There on Broncos as well as any other tailgate mounted spare , you barbiphobic you afraid of pink Corvettes and red Ferraris as well?  ::)
Pinstriper
OJ drove a Bronco.
But if a red Ferraris pulled up alongside me, I'd hope it was Christie Brinkley behind the wheel !
I need a sandwich.
Let's eat Grandma !
Pinstriper
It is all coming together nicely. I still have to figure out tiedowns, thinking a full loop around the kayak body to the load stops on the rack at both front and back, plus a simple line from the bed rail points over the top, again at front and back, should do it, no need for bow and stern.
Let's eat Grandma !
Pinstriper
Since I also have tiedown points in the middle of the bed (above the wheels) I'm also planning on running through the handles to be sure she stays down and no forward/aft movement.
Let's eat Grandma !
Low_Sky
Just in case you didn't know, Hobie recommends upside down on crossbars.
2016 Hobie Revolution 16
2014 Perception Triumph 13
Pinstriper
They can recommend that, but it would be too many opportunities to break stuff I have mounted to the gunwales, which would also be bad for the boat.
Let's eat Grandma !
Low_Sky
I definitely see the appeal.  I transport mine upside down, but I slide it on from the side of the truck.  The sliding is across the length of the bar, not the length of the gunwale.  If I loaded my kayaks from the back of the truck, I'd probably do it with a cradle up front and rollers in the back, with the boat right side up.
Pinstriper
I am probably too old, and certainly too fat, to be able to fling this kayak up by its side.
I think it will be OK so long as it isn't there for extended periods. Overnight before heading out, and in transit, I think I'll get away with it.
Let's eat Grandma !
RoxnDox
  • Native Propel
  • Date Registered: Sep 2013
And that was the biggest reason I ended up getting a pickup...  I can lift a boat waist high easily enough, but car topping was getting a little, ok a lot, more challenging...
dandj1958
  • I fish like a girl
  • Date Registered: Aug 2014
+1 on Hullavators!  I just love the two we have.
Julie
AKA mrs. dannybay
2015 Hobie Revo 11
2012 Hobie Revo 11
