November 06, 2026, 05:36:56 AM
Topic: Mirage Drive Storage  (Read 11434 times)
I've been meaning to rig up something similar to what QuillbackBob did - I think that having some bungee on the bow designated for drive storage is the way to go.  I've done enough surf launches/landings to feel like I want the drive out of the cockpit area and strapped down.  It is pretty cumbersome to have it under your legs when you need to jump out quickly and grab the yak to avoid getting dumped by a wave.
jstonick
I love this thread. I am waiting for all you guys with tons of experience to figure out what you all feel is best then I will just copy it.
You guys are like scrubbing bubbles, you do the work so I don't have tooooooo :)
Romanian Redneck
  • snoodleboob smoochy bear
Now that's funny. :)
RR's Channel
- Jeff Foxworthy
Romanian Redneck
Do any of you use a leash for your mirage when not using this method? I currently am using a Hobie rod leash that I have attached through the back of my mirage drive and connected to  the hatch bungee. Just in case I need to remove my drive while on the water and  accidentally fumble it over.
RR's Channel
- Jeff Foxworthy
jstonick
I got the Hobie drive leash and always use it.
Romanian Redneck
Is the drive leash much different than the rod leash? The Hobie rod leash seemed to fit the mirage well and seems pretty sturdy.
RR's Channel
- Jeff Foxworthy
Yup.  I use the same leash that I use to lash it down with.  It's about a 20" by 1/4" bungee with a brass clip.
The pad eye I added near the mast hole is where I attach to in all scenarios.  It is currently a plastic eye with a small metal backer plate, but will soon be changed to a stainless eye and a bit larger metal backer plate.
« Last Edit: March 24, 2012, 01:03:34 PM by INSAYN »
Romanian Redneck
That looks alot like the stock Hobie leash. Only thing that concerned me about the Hobie leash was that it had a plastic buckle. But it seems pretty sturdy even pulling on it hard.
RR's Channel
- Jeff Foxworthy
Don't know what the stock Hobie leash looks like.  Mine didn't have one, so I made my own.  I think I'd trust brass over plastic any day for this jobber.  8)
